Yes streaming service apps for tv or movies like YouTube etc, I have tried one from mainland China the app works but after clicking on videos it won’t play it gives an error telling me my location doesn’t allow it, it won’t even work with VPN
Taiwan does have streaming services, but I’m not sure if PicoPix Max will perform. E.g:
- myVideo: https://play.google.com/store/apps/details?id=com.taiwanmobile.myVideotv
- ani.gamer: https://play.google.com/store/apps/details?id=tw.com.gamer.android.animad
- KKTV: https://play.google.com/store/apps/details?id=com.kktv.kktv.tv
Hope this is the information you want.
Great thanks for your help exactly what I’m after, I will try and find it in aptoide store or maybe the apks online and see if they work
Hello I am from Taiwan, my ID: 18704, when will my projector be received, I have waited a long time
Hello, Philips?
Ok tested out all 3 last night
myVideo displays a message
Once click on confirm it just exits the app, think google services are needed, so definitely won’t work, -
KKTV also needs google services, warning is in English app won’t launch further, not working,
Ani.gamer, good news although it also says it needs google services but just ignore it and it works, it’s also geo restricted for Taiwan only but I got it working with a VPN, played smoothly only in 360p, to get higher resolution you need to sign in but no option to register on app, so for Taiwan users at least this app should work great, although it’s all anime in Japanese but with Chinese subtitles
And though it’s only 360p because it’s animated and not live footage it’s actually not bad and very watchable compared to other 360p resolution
@IvoGrijt Any news for the batch list joy. My contribution number is 20905 and I haven’t receive any tracking number.
@IvoGrijt, any news on the betty batch? Most of the backers in Taiwan of this batch have already received their PPM, but I still don’t have any updates on it. Please help to follow. Thanks.
看來好像蠻多人還沒收到貨,反查了前幾天查到的TN(tracking number),好像還有卡在物流的。 透過底下的網站, 可以查到更細物流狀況, 至少可以看到收件人的大致姓名,例如底下這個狀況盧先生有看到的話可以打去問問問看。
http://125.227.139.70:8086
另外像我即使收到貨了但我的backerkit還是沒有顯示出貨, 甚至也沒有TN. 所以我懷疑philips可能也沒有TN, 也就是目前的狀況是, philips 把貨送出去給一個很爛的forwarder, 即使我們提供了對的訊息, 但物流把地址亂翻, 運氣好的backer名字電話是對的,還可以聯絡到人. 運氣不好的就變成幽靈包裹了.
之前有試著寫程式, 因為怕影響到物流網站的流速, 加上不知道TN的數值範圍有多大,以及到底這批有多少人,所以沒有大量反查(畢竟範圍有5位數). 後來有試著透過查詢關稅局網站想找出這批空運對應的主提單號碼也許就可以查出這批貨所有包裹,但看起來關稅局的資訊還是很不明確,所以就卡住了。 之前好像有人有打電話問過報關行,也許可以試著問問看"主提單號碼",再透過底下的網站也許就可以取得更多TN,再透過物流網站就可以查到更多幽靈包裹。
請問我怎樣可以得到主提單號?就是你用程式生成出來測試嗎?
正常管道應該是你去問philips說的那個物流,提供你的資訊(姓名與手機),應該可以拿到幽靈包裹才是。
關於
每個backer可以從EZWAY可以取得他的分提單號。
目前看分提單號就是tracking number. 也就是可以從物流網站查到的號碼。
但這些資訊只限於個人而已,無法知道同一批的人的狀況。 但如果可以知道
主提單號,透過我說的網站。也許就可以拿到同批的清單,例如底下的例子,
就可以列出來一串分提單號。 而我只是寫個程式,使用CVTExxxxxxxxxx去查幾
個有結果的。
不過這個資訊philips應該也可以拿到才是,畢竟他是寄貨的人。
My contribution id is 18584, backer_id is 15805550, seems to be on batch Laurent.
Is there any update of my parcel?
有人也是分到Laurent這組而收到東西的嗎?4月中有提供過身份證資料,以為很快就會收到的說…
我用 cmwang 教的方式掃了可能的分提單號,目前看起來有大約十人還沒有收到
為了避免有個人隱私外洩的問題,我就不將列表貼上來
如果你是屬於 betty 這一批,且還沒收到貨也不知道分提單號的
可以PM給我你的中文姓名及寄送的縣市
如果跟分提單資料一樣的話我會給你你的分提單號
你再拿這個分提單號去貼心物流查詢目前貨物的狀況
您好,我剛剛有發現我在 batch Joy裡面,這是代表我應該還在寄送中對嗎,不好意思,因為現在另一個討論那邊也是亂成一團,問了也石沉大海,您似乎可以自行想到一些方式可以了解狀況,如果有什麼資訊可以提供的話,不知道是否可以幫幫我呢
給你一個讚!
問一下後來你掃的總數是多少個呢?
另外有收到的也可以分享一下ID,這樣也可以讓台灣的backer,了解實際的配送狀況。
例如我的是
Contribution ID: 10673
Batch: betty
Status: 6/18 收到。
讚喔,比我現在用相機包當攜行體積小很多。可以問一下Go pro 硬殼包的型號嗎?我也想試著自己做一個。
It seems that the TV version does not work, maybe the mobile version of the app can? The following is a link to the app version.
我是在 PCHome 買的
