@williammuk Is there any need do adjustment to the picture? The colours from my ppx looks alittle washed.
Did you go through the pairing mode as advised?
After first paired, I think I only ever had to pair it again after one of the earlier updates.
Yes. But the Airmote doesnt appear under the available devices.
Press &hold down and OK (Notice blinking happens almost instantly)
Search device
After which nothing else happens.
wowâŚthatâs great! is it via usb-c? how fast the Xiaomi 20000mah powerbank charging the projector, guess youâre charging it while projector is running, so just wondering hows charging speed like 1 minute how many % gets charged, even if its slow charge, xiaomi still can help to run the projector longer than ~2 hours its battery lifeâŚ
I havenât got mine, i am in list 3, no tracking so far @Bryan_Tong @Kenneth_Tham are you guys in list 3 also?
I am usually using JBL Flip 5. Sometimes the Sony WH-1000XM3 headphones. I have tested Sony SRS-XB10, Apple AirPods 1st Gen and Xiaomi Haylou GT1. All works via Bluetooth.
Maybe you take a look at this post and check that your brightness and contrast is as shown in the post. Mine is set that way.
Itâs âOKâ (centre of direction pad) & âVol-downâ (Button at left of Autofocus).
The combination of both buttons will result in continuous blinking of red LED between power and mouse buttons.
It kind of extended by an hour plus. I will suggest using to charge when power off. (Less heat). Trying to see how much capacity charged with powerbank
Early list 3, the May 18 batch
Thanks! I think mine is already set to that config.
Ah! I think I might have pressed the wrong button. I will check again. Thank you !
Thanks for the correction and info !!
Looks like new tracking info has been uploaded. I just received email stating mine is shipped. FYI, I was part of the Laurent list 3.
The wait begins for the final leg 6 month long journey!!
yayâŚI just got the tracking number too
not bad, 3 hours should be good, longer than heavy userâs laptop battery
Finally got my tracking number too.
i bought a foldable one from Sxxxxx.sg⌠havent used it yet⌠have tested on my android box though
letâs pray we dont have lemon setâŚ
I also got my tracking number. Was part of Betty/Jordan batch
will u have 2 units?
