That does work already, doesn’t it? Sure only vertical correction works automatically and for 4 corners you need to do it manually. It does work however and actually I’m trying to always center the projector, because you’re wasting screen resolution when you use too much screen correction, because what it does is to transform the screen via software.
I think it boots fast enough… I can wait 10sec to boot up and what 3 hours of content. “Default output” I don’t need, but would be a nice enhancement, but thats no pain for the usability at all.
my clock is 24h per default in my timezone… so not sure what the problem is for you
I had never problems with wifi after a reboot. Perhaps get a better wifi router. I can recommend all Fritz! devices.
No lag on my device. Once it is booted up and you give it a secound… it’s fine. Sometimes I can hardly see what app is selected though. A better indication for that would be cool.
You can do that… I mean, at least remove the bloatware… select the app, hit menu button on remote control, select uninstall… done…
Reordering would be cool, yes.
I would say you can do that, you just dont see the focus overlay, but can adjust the focus with left and right on the remote.
That’s nice to have but no real “need” to work with the projector
can confirm that and also german does not apply to every section or home screen anymore… I’m one 1.1.0.3 though, probably that’s the problem for me, but I’m afraid it might work worse after updating.
I can understand that “no apk updates” in the updates and I’m also wondering why that’s made. I have updated my apps via AptoideTV so far and that worked great. I haven’t touched the Netflix app however.
I guess this is not coming, as the OS is a mobile android, but google requires to have a touchscreen to certify a custom OS with google services. But you can login to your youtube app just fine… what else would you need google for, if playstore isn’t there anyways?!
