Hi all.
My PicoPic Max will not start up.
Projector starts up - showing the Phillips logo and the fan i running. Then shortly after shuts down again, leaving the light bulp on, but no image.
I see there is a full thread about this, but cannot seem to find a solution, so I was wondering if any of you guys, who experienced the same problem, had any luck to solve it somehow?
I really don’t hope that I have to return the device.
Thanks.
Hello @DustyBottoms please follow the Cable restore procedure to completely erase and re-install the latest firmware. Let us know if this still doesn’t solve the issue.
(Unlisted this thread to keep it focused on your issue).
Hi @Philips_Support_P
I tried to follow the instructions, but I cannot download the file that you linked to ( Download v1.1.03 from here 1.99 GB)
I am stuck now with a device that says “No signal” on a green background
Still hope you can help me.
@Philips_Support_P
Could you please return a comment.
This is starting to get really frustrating.
Thank you.
Hello @Philips_Support_P
Could you try to send a working link?
The link in your “Cable restore procedure” is broken.
Thank you.
