I loaded the Peacock TV app from Aptoide TV on my PPX but the app wouldn’t work. It just says “Sorry, Peacock is unavailable on this device. Please see peacocktv.com for supported devices.”
Is there any way to get it to work? Thanks!
The funny part is when I first downloaded it and opened it about 2 weeks ago it worked without a problem but now im getting the same thing
Has anyone figured out how we can watch peacock TV especially the Olympics on our PPX? @Philips_Support_N
we will test this apk: https://apkpure.com/peacock-tv-stream-tv-movies/com.peacocktv.peacockandroid/download/121030105-APK?from=popup%2Fversion
App still says not compatible.
No superbowl.
Tried the app from the link above. Its not compatible still. Any ideas @Philips_Support_N ?
Hello, we will test it this week. We need to test the right version.
The Olympics are over, but I would still like to figure out how to get Peacock to work on the PPX. Any updates @Philips_Support_N ?
Hello Bryan, we tested many version but it seams Peacock is blocking their app by device.
@Philips_Support_N, Thanks for checking.
@Philips_Support_N @Philips_Support_P The olympics is back and we want to stream on our PPX. Peacock is the only app that streams the olympics, it still doesn’t work. How can provide support to make Peacock work? Thank you.
