Hello beta testers,
We have a maintenance update available for your testing and feedback. V1.3.0 has:
- EasySetup is now included by default. You can run it manually, or it will start the first time after a factory reset, helping you select the language, time zone, pair the remote and setup WiFi.
- the projector now autofocuses on every boot
- the Launcher has been updated to 1.8.3 with updated Philips typeface and bug fixes
- the recent bug with black screen after updating the launcher should be fixed
- translation improvements, particularly with app update feature of the home screen
- internal stability improvements
You can download the update from here. Then follow the steps in INFO: How to do offline software update?.
If we don’t hear any showstopper issues, we plan a general release this week. Thanks for your feedback!
