Hello, technical support.
I have a problem.
I used the projector normally for several months, everything is fine.
It stopped starting normally this week.
I am using an original charger.
Fully charged.
The blue indicator is on.
If I touch the touchpad on the case, a cursor arrow appears.
What should I do? How to reset to factory settings or reinstall the operating system.
See video. https://photos.app.goo.gl/rKDjvP7ZMN1hS2TY9
There are 2 pin holes on the right hand side of the PPM. The one near the USB ports or the back of the projector is for the Service menu which you push in to access basically the Android version of a Bios. The Pin hole facing the lens is for a hard reset, I’m not too sure how it works as I haven’t looked into this, so I would advise you search on this forum for more information.
I would imagine if you Push it in the device will cut the power to the memory/storage which would wipe all User Data and setup configuration. Then when it powered back on it will be like setting it up again.
The other method is to a get a USB cable which has USB C and a standard USB which can be connected to a computer. If you raise a support ticket with Philips they can send you an image and software which can be used to Fully flash a new OS image to the PPM.
I have tried the to get the service screen ans have not had luck. My unit will not load the OS and the remote controls seem to not be working, and it will not turn off unless I hold the power button for 30 seconds (give or take). However the hdmi works fine, I just cannot change the volume or turn it off easily. Any suggestions on the solution, or what am I doing wrong to get the service screen. I pressed the back reset button and pressed and held them through the rock chip screen and nothing, after the Phillips screen it goes blank. HELP!!! PLEASE!!!
