I have been trying to pair my JBL Flip 4 to the PPM with no success. For some reason, the bluetooth speaker does not seem to show up on the PPM pairing screen, even though other devices such as my phone are able to pick up the connection and even connect to the speaker without any issues. What could be the problem here? Thanks for the help!
I have the Flip 4, one thing I’ve ran into issues with the speaker in the past, is having paired too many devices to the speaker, there is a maximum, you might need to do a factory reset on the speaker.
Thanks so much for the tip! I did a hard reset of the speaker and am able to connect it to the PPM now
FYI (and for other people in the near future) one JBL bluetooth speaker works fine. If you try to add two of them (in Connect+ mode between themselves) then the audio is not synced to the video.
I haven’t found a solution to this yet.
I tried this with 2 Charge 3’s, using the latest firmware.
