I have been able to play a bit with the Pico and have a problem with the USB videoout.
I mainly want to use the Pico Max on the go. That means that I want to use streaming apps with my smartphone and mirror the picture with USB-C.
Why am I doing this?
In Germany, T-Mobile has a tariff with unlimited data volume for streaming services. In order to use this, I have to run the streaming services on my smartphone on the go.
WIFI is usually not available.
So far I’ve been able to test the following
| Manufacturer | model | video out via usb-c works | supports ALT Mode HDMI | supports ALT Mode DP |
| Pixel 4 | ![]() |
| Samsung | Tab 5e | ![]() |
| Samsung | S9 Duo | ![]() |
| Samsung | S20+ | ![]() |
I talked to the Samsung Support and I was confirmed that the s20+ supports ALT Mode HDMI and DP
