I was initially disappointed when reading the user guide projector_manual_11843.pdf (projectorcentral.com)
It says only Fat32 is supported, which means only 4GB files max can be used? That’s kind of limiting. That issue was also raised in an independent test I think (don’t remember which)
I tried reformatting an NTFS key into exfat rather than FAT32, and it works like a charm - larger files can be played, Screeneo updates work as well.
@Philips_Support_P the user guide should be updated accordingly?
