Hello everyone when I launch the Disney+ application to watch a movie in IMAX with Dolby Vision I only have thé Sound but no image.
If i lunch disney + with my ps5, with thé same film it’s ok but i am in hdr10 and no more dolby
Thanks a lot
Thanks a lot
I have the exact same issue… I noticed that I can launch some show or movies without problem when they are not Dolby Vision (as example Mr and Mrs Smith is working, it’s SDH - The Devils wears Prada - 4K Ultra HD, HDR10 and SDH). But other movies that are Dolby Vision compatible are not working. The image is black and I only see the subtitles. I also noticed that if I change in the Picture Mode while playing the movie and select Dolby Vision Dark, I can see an image (with the wrong colours / in Dark mode). Dolby Vision Bright and Dolby Vision Vivid are not working…
How can we fix this?
Good question … may be philips can answer us? ^^
So the solution is on the page of indiegogo about the Screeneo u5
Go to that page et follow the link to download the file
Here is the solution:
Please download this new software and install it: SwissTransfer.com - Envoi sécurisé et gratuit de gros fichiers
Steps for local upgrade:
I have one major problem: Dolby vision is not working.
I have updated the last firmware (3 aug 2023). Nevertheless i have a black screen.
I use apple TV4K or a Bluray, connected direcly with a certified HDMI wire. all is fine with HDR. but when you use Dolby vision it is a black screen.
I have tried to reset but it is always the same.
DO you have the solution ?
thanks
Hello!
This problem is back … how can we solve it ?
Thx,
Johan
