Hi guys,
I try to use my PPM Via Airplay with different divices (Ipad/Iphone/Macbook). I can always connect to the PPM and in the case of the MacBook even see the workplace/homescreen. But if I try to play a video the Player stays Grey and only the sound is transferred. In windowmode I can see the workplace but the windowed player stays Grey.
With Iphone and Ipad all videos play only the sound. YouTube, Amazon and even my own self shot videos from the photo app.
What can I change to get the video running? Or is this problem related to the missing AirPlay2 Standard?
Hi LLG,
Thanks for your reply.
Yes, I do play all of my divices on my AppleTV perfectly fine. I will upload a video tomorrow. Maybe this will help to better understand the problem. And I plan to change my router. I’ve read that this helped somebody else.
I think this might be DRM blocking the stream. It becomes grey as soon as you turn on mirroring. The same happens if you play Netflix in your browser and try to screen mirror it.
Ok, this is already nitpicking, but depending on your location even solution #2 might be illegal. Not that I necessarily discourage doing it anyway, just something to be aware of.
You’re right, but in France we are allowed to make a “private copy” of DVD we own .
Talking about DRM removing, it’s more blurry, but tolerated…
Yes, it’s specifically the removal of DRM that creates the legal problem. In some countries it’s considered legal for private copies, in other countries circumventing any copy protection makes the whole thing illegal.
From few weeks, my airplay do not work very well.
I am able to share the screen of my laptop or iphone in airplay, but if i use a streaming website and try to share the movie with Airplay it doesn’t work.
The screen is black, i can see my pico trying to load the movie and after a couple of seconde automatically back to “home”.
Work pretty well on my TV with Apple TV but not anymore with my Pico/Airplay.
This sounds like a DRM problem. Streaming services are sometimes quite restrictive with what they allow to be done to their video streams. Many of them prohibit casting it.
