Simply, would be nice to see the network name connected to and whether WiFi is actually connected without having to go to the WiFi menu icon around the upper area of the UI.
Having multiple SSID’s I connect the PPM to even in one location (testing/differing 5GHz or 2.4GHz SSID), you’re forced to check you’re connected to the correct network when it could be displayed in the ample screen real estate at the top alongside other icons/clock etc.
