At first I got an issue getting Disney+ working on my PPM.
So I googled and found a solution for an other device (Android TV OS running) and I tried that solution and that worked for me:
- Go to https://apk.support/download-app/com.disney.disneyplus
- Set device to TV, android to 8.1
- Click generate download link
- Download the three apks that were generated (base and two config apks)
- Now download SAI https://apk.support/download-app/com.aefyr.sai/1569816000_vs-2.8
- Install it
- Through SAI install the three apks you downloaded earlier
Enjoy Disney+
It might also work for other apps.
I tested it also with NLZIET.
Also might work after malfunctioning apps after updating.
It worked for me, so I tought to share it with you.
Might work for you too!
Good luck!
