Just upgraded to 1.8.1 and now the launcher does not start, it flashes for a second as I turn on the projector and closes, then tries to start again repeating this behaviour in an endless loop.
How can I downgrade the launcher if I do not have access to it?.
Spamming the mouse cursor on the settings icon, let’s u enter the settings menu, and from there u can perform a factory reset which solves the home screen boot loop problem.
Do you mean the three dots and three lines blinking on the right ?
Because I don’t see anything else on the screen and this doesn’t seem to do anything, although I’m clicking with the mouse pointer several times per second…
Keep spamming with the nous cursos, even when it’s on its black screen. Just spam on the cogwheels icon. It’s in the right corner on the right side of the battery icon
I see now which icon that is, that should be the icon on the home screen of the apps.
Try pressing arrow up button first to get into settings area of the home screen.
If that works u should see a cogwheel icon. Otherwise try turning of and back on again. And see if u get to the settings area where the cogwheel is shown.
Just to share some information, I was on firmware 1.2.4 and the updated launcher 1.8.1 caused this looping problem. Managed to get into Settings by spamming the Settings icon (top-right of screen). Then I tried updating firmware to 1.2.7. It updated successfully but still hit the looping launcher problem upon boot up. I reluctantly did a Factory Reset and it is OK now. Have to reinstall all my apps again.
