PicoPix Max One? New model being released
Hi guys! Can someone explain what are the differences with this projector? What is the operating system? Does it has the same limitation such as horizontal keystone correction over hdmi?
Article says it will cost 529 USD, which is actually pretty competitive.
Regards
In this article the last 2 photo’s of the projectors are swapped,
but at the end it says that the Picopix Max One runs on Linux and that the battery should last 5 hours.
So what is the OS in the new Max? My only grudge on the current is the hardware is slow!
The details seem vague and sounds like the things they’ve done in PPM’s firmware updates. But if it’s actually a Linux OS then I would assume it’s not a ā€œsmartā€ projector anymore so it’s a lot cheaper?
It looks better though, I like that it’s not non-shiny
ā€˜Picopix Max little brother’
I’m wondering if the same hardware limitations apply to the Max One, or if the HDMI problem has been fixed:
4-corner-correction and Bluetooth with HDMI and USB-C sources
If they made it work, I’ll gladly have another look at the new projector, I don’t need the smart part at all.
+1 if this new model fixed these issues, I am ready to switch over
Has anyone checked the dimensions if they’re the same?
I feel like the details are still not enough or a bit vague. No mention of lemons.
Also, the store says Netflix and Prime is preinstalled but the document says it has Linux as the OS. I don’t think there’s a Netflix app for Linux.
Also,a notable difference as well is the DC port for charging instead of type-C. That for me maybe the deal breaker. Hopefully, they release PicoPix Max One X next year with real improvements or PicoPix Max Series X for next-gen projector experience :laughing:
According to the PDF @Dean_Newton attached, it has HDMI ARC AND CEC Support. Looks more like a twin updated brother than ā€œlittle brotherā€.
It looks like a real public version, which can be sold in the real market.
The ppm will stay an indigogo version for nerds :slight_smile:
We were the beta testers for this stable version
Hello guys, the Max One is a downgrade from the Max, like a little brother. We removed the OS, removed all smart function and made a very affordable Full HD with the same light engine as Max. 4 corners is now working everywhere and for sure, as there is no OS, nor wifi or Bluetooth, the battery is now going up to 5h. (same battery as Max).
No autofocus but electric one, no touchpad.
Sound is netter compared to Max, the size of the speaker is the same but better driver.
No, we are selling it everywhere, even at Best Buy or MediaMarkt
No Bluetooth?
no, this is a very simple Full HD projector. We removed all smart functions compared to Max to get a very aggressive price.
The problem a lot of people had with the Max, even prior to the shipping kinks, was the missing functionality on HDMI (or USB-C for that matter). It’s sad that even the updated version doesn’t bring those sought after hardware upgrades to the table. I think it’s finally time to lay my interest in the PPM to rest, for good this time.
Thanks for clarifying the details. I think it’s a good projector for those who just want to have portable projector which you can use with an external source. PPM’s internal software wasn’t good anyway although personally, I still want the smart functions even they’re a bit mediocre.
Will it be possible to downgrade the picopix max to this firmware/software. I use an android TV stick on the HDMI port, so I don’t need wifi, bluetooth, or any apps on the projecter. I just want the oportunity to adjust the picture of the projector while using the HDMI port. Hope I can get this ā€œdowngradeā€ on my PPM cause then it would be perfect for me.
My guess is that it won’t be possible since they still have differences in hardware. My suggestion would be to sell your PPM and get this one. You might even a few bucks back :smile:
Hm…, combine that new PPM ONE with an affordable streaming stick and you end up with a better deal than the regular PPM… imho…
yeah i would also jump on that tbh…
